angel_grig
I've recently found a breadbin C64.The computer is without a power supply so build one myself with a 9v ac adapter and an AT power supply.I used the schematic from herehttp://www.hardwarebook.info/C64_Power_Supply but I connected the +5V to the pin 4 because checking with the multimeter pins 4 and 5 are connected inside the computer.After powering on, the LED lights but I have no image.My AT power supply outputs 5.35v(as my cheap multimeter indicates).In a SAMS service manual I found that the DC input must be at 5.09v.So,what do you suggest?Should I connect the power to the pin 5?Is 5.35v too high for the c64?Or is it a fault that was already in the computer?
Thanks in advance
Thanks in advance
