| VCF Latam | Apr 24 - 26, 2026, | Bahía Blanca, Argentina |
| VCF Pac. NW | May 02 - 03, 2026, | Tukwila, WA |
| VCF Southwest | May 29 - 31, 2026, | Westin Dallas Fort Worth Airport |
| VCF SoCal | See you in 2027, | Southern CA |
| VCF East | Apr TBD, 2027, | InfoAge, Wall, NJ |
If the system itself works, I would assume the character ROM has gone bad.
@flash951 This does raise some questions. What happens when you try to load games from disk or cartridge on your 64G? Do they load and play fine like they do for Timo? Also, what was done to confirm that the sockets and Character ROM's were functional?Text mode looks garbage, just like in flash951's screenshot. The system works, however. You can type and run BASIC programs, load games from disk with perfect sound and graphics etc. It's just the text mode that is messed up. Also, Dead Test just shows a pink screen. Though I'm not sure if the version of Dead Test I have actually supports that board revision.
If you don't have a spare, the modern replacements are fairly inexpensive and do a pretty good job.I'm pretty sure the MOS 8701 is shot. Have to check if I can find a spare from a working machine to test.
Is there any change if you gently push down on the Character ROM while the computer is running? To me it seem that both may be good (The ROM is working and the socket has no broken leafs) but something is not making full contact/connection. Have you tried DeoxIT or something similar in the socket, and check for any cracked solder joints on the board, especially the Character ROM socket, but I would check the CPU and the PLA as well for broken joints, especially if disks and carts load funny as well.
Can't speak for him, but pressing on chips has no effect on mine. Only the SID and VIC-II are in sockets on my board and the contacts are fine.
When pressing and holding the reset switch on the Dead Test cartridge, the garbage characters go away and I have a perfectly (frozen) screen as long as I hold the reset switch.
Funny... yesterday I took a C64G that I got a while ago out of storage for testing/restoration. Guess what? It has *exactly* the same fault!
I've ckecked all IC's, including 8701. Dead test runs, got it in Flash bank of MMCReplay. Also just got the new DesTestMax cart. Ive now checked all traces from U8 mem controller/mmu/pla and char rom. Will check traces from 8701 tonight.I'm pretty sure it's the MOS 8701. It must be some timing issues while reading out the lines from the character ROM.
I have a C128 with a 8701 that I can swap for testing, but I'm busy with other projects now and the C128 is in storage anyway.
btw, does the Dead Test run on your machine?
I am not sure which revision of the board you have, but if you have a 250469 rev B, you can buy a new old stock SuperPLA here:After some more testing, I fear it's a fault with the SuperPLA on my machine. The cartridge port does not work at all - not just the Dead Test. Depending on what cartridge I try, I either get a black screen or the system just starts BASIC, but with reduced free memory (so it sees the ROM and maps it into memory, but code execution does not happen).
