alexkerhead
OK, the CBM 8032 came in, and boots fine, and accepts the usual basic commands.
BUT, when I type load with the C@N hooked up, it says "hit play" so I hit play, it says "searching" and the tape wont move. It seems like there is no electricity going to the motor....I tried two different WORKING C2N units, both do the same thing.
So, I cleaned the connection on the back, and cleaned the connections on the C2Ns, same thing......
Try the C2Ns on the VIC-20, they work fine.
I had them grounded as well, then tried ungrounded....
I also went inside and checked for burnt leads, or unseated chips, nothing was out of order, but I reseated the chips anyway..
Ther C2Ns still wont work.
Is there something I am, not doing?
Or do you think it is just a lost cause?
