Hello again,
i have a PC30-III recovered in a abandoned house! This machine is the first revision with battery externally of the RTC chip. This computer results totally dead, no power completely. After repair power supply the machine not boot, no video output, nothing.
I have checked, revised, cleaned all the battery area and i have found only two pcb wire interrupted, and three logic chip faulty, the chip involved in a reset circuit and keyboard controller circuit. Replaced all with new one and repaired the wires i have modded the board to use a DALLAS 1287 RTC chip, i have another working PC30-III with this and i have removed component not used with DALLAS.
Then i have tested the VGA ISA card in another computer and it results faulty and replaced with another working, rhis machine not post anything without video card and hangs during post. Then i have found a PAL chip faulty, replaced with my working PAL from my PC30-III working and now i have a POST and boot screen but......
I see video card model installed, boot screen with commodore BIOS version and it start to test the RAM memory but it stop to 256k and going to reset loop.. then again 256k and reset...
I have tested all chip RAM with my PC30-III and with DRAM tester all results ok, and all logic involved to memory controller and not involved, the delay lines too, and all socketed chip, CPU too, and all PAL chip on my PC30-III, all is working perfectly, but on this board not, it's stay to same problem of 256k ram and reset.
The RTC dallas chip have external battery disconnected and resetted, don't have BIOS setting saved. The keyboard controller is ok tested, but i don't have any access to BIOS settings with pressing CRTL+ALT+ESC keys...
Any help to me to other check?
Seems all wires are ok, tested connection with chips and schematics. Suspect to CPU socket, but i'm not sure..
Thanks
Emanuele
Thanks
Emanuele
