| VCF Latam | Apr 24 - 26, 2026, | Bahía Blanca, Argentina |
| VCF Pac. NW | May 02 - 03, 2026, | Tukwila, WA |
| VCF Southwest | May 29 - 31, 2026, | Westin Dallas Fort Worth Airport |
| VCF SoCal | See you in 2027, | Southern CA |
| VCF East | Apr TBD, 2027, | InfoAge, Wall, NJ |
I tried another cpu and it is the same result.Either you have a duff 6502 CPU or there is something pulling this signal HIGH.
The PIAs and VIA will not work without this clock being present.
It also depends upon whether the RAM and ROM replacements use this signal.
Yes those items have all been out with our tests.Well at least it's not my NOPPer.
I guess leave the 6502 out for now and trace phi2 backwards...
Have you removed as many things as you can that consume phi2? PIA @ B8, VIA @ A5, PIA @ G8
Have a look at C8 pins 5 and 6
If pin 6 is anaemic is pin 5, which should be the inverse?
Yes... and No... try both.Yes those items have all been out with our tests.
So when I test C8 shall I remove the cpu.
Will do later.Can you not tweak the time base to make it more interesting? This is a fast signal.
Looks like my readings this morning were D8, that’s what you get for rushing.Please do tweak but the fact you have two lines above 5V apart looks good.
And the previous pin 39 reading makes no sense.
Once you have interesting traces also try pin 39 of the CPU socket
After that if you add the NOPPER you can also measure pin 39 on the top left pin of the connector at the left top for fun
All those should give similar traces to pin 6 of the flip flop.
Enjoy work
Why?Pin 39 of F3
Just measured its voltage. Just under 5v. Shouldn’t it be 2.5v
My fault for doing research on Google and getting an AI answer lolWhy?
It is a TTL signal. A TTL output signal should 'swing' below 0.5 Volts (for a logic '0') and above 2.7 Volts (for a logic '1'). See https://www.allaboutcircuits.com/textbook/digital/chpt-3/logic-signal-voltage-levels/. Anything in between 0.8 Volts and 2.7 Volts is "undefined".
I am not sure where 2.5 Volts come from.
It should certainly not be as it is. Any TTL logic input will see this signal as a permanent logic '1' (which is what G3 is).
Sadly I only have one X1 probe.I'm sorry I was being a bit slow...
So you have a good clock on pin 37...
What is happening on pin 3?
Pins 3 and 39 are signals generated by the 6502...
It would be fun to trace pin 37 AND pin 3 simulatenously
Here is pin 3Sadly I only have one X1 probe.
I will check pin 3 shortly
