Nivag Swerdna
Very nice. That is what pin 39 should look like.Here is pin 3
| VCF Latam | Apr 24 - 26, 2026, | Bahía Blanca, Argentina |
| VCF Pac. NW | May 02 - 03, 2026, | Tukwila, WA |
| VCF Southwest | May 29 - 31, 2026, | Westin Dallas Fort Worth Airport |
| VCF SoCal | See you in 2027, | Southern CA |
| VCF East | Apr TBD, 2027, | InfoAge, Wall, NJ |
I see. Just need to find out why it isn't.Very nice. That is what pin 39 should look like.
^ Socket G3 and test pin 39 again without a G3I see. Just need to find out why it isn't.
Have I done everything that we spoke about upto this point.
Oh my. Pin 39 unloaded.If you are feeling brave... Before you warm up the soldering iron...
You can bend out pin 39 on the CPU and put the CPU back in it's socket
You can then measure an unloaded pin 39
Remove; Socket; Measure before inserting a new one but with the CPU pin back in the CPU socket.Oh my. Pin 39 unloaded.
So I guess I will remove G3 sn74ls00n next and replace in a socket.
Sorry I didn’t see this but good news anyway as we have made progress.Remove; Socket; Measure before inserting a new one but with the CPU pin back in the CPU socket.
I plan on keeping it as it is. I do have two other pets with disk drives. Those pets have memory issues that I will get round too.Drum roll!
Check the ROM checksums and make sure the RAM test has a good 'thrash' at the RAM.
Then start building the machine back, bit by bit, testing as you go.
What is your aim for this machine?
If you want to add a disk drive of some sort, there is a book containing a simple BASIC program you can enter to test out the IEEE488 port. I reference it quite a lot...
Can’t believe I did not see that lol. I have since read it in the Rossi read me file. I’ll do this when I get back.If you are thinking about using the H7 gadget I think you need to get it working again as PET TESTER first. Sound like you might have H7 socket issues?
You can use VOSSI to sum H7... Follow the very obscure instructions at the top right of the screen!
