Hi,
I continue my adventure with PET 3032 and now it is time to get 8050 drive working.
I finally got a cable, connected it and bought some old but new and never used DD floppies. The drive seems to initialize correctly - it ends up with center green led on.
I tried formatting the disk and got of course into a following problem:
Pawel
- the drive spins up, the head moves several times a tiny bit in both directions, then it moves all the way out to the edge, motor buzzes, head moves to around a center, stops and center led goes red.
- the error code read after that is 20 - read error
- this behavior happens also without a disk (shouldn't it detect there is no disk and do nothing? disk presence switch works fine, as it spins for a while after inserting a disk)
- this behavior is the same on both drives
Pawel
