Commodore PET Kernel Source
hexsane
Omaha, NE USA
Anyone know if this has been reverse engineered and is floating around somewhere? I need to see the feasibility of doing a few modifications.
-Matt
One thing that may aid your search: the Commodore crowd like to spell it "kernal" (with an "a"). Google will try to "correct" your spelling, but you will get some different results.
Are you aiming to patch the original ROM? It may be easier (and more elegant) to put your modifications into a separate expansion chip.
For compatibility reasons (kernAl calls from ML) I will have to jump out of the kernel and run my own code (if needed) then return.
BASIC extensions I can do. But any direct ML calls will kill compatibility and I'd like to be as compatible as possible.
-Matt
Matt,
Yes. But a non-commented listing would do. ;) Basically I'm trying to save myself a few steps if possible.
-Matt
in order to obtain a raw version of an undocumented PET kernal disassembly, you might be able to use the VICE emulator's built-in monitor, which also features a disassembler. Haven't found out how to write its output to file, though.
Regards --
There is a Perl tool called recomment which I highly recommend. You take a binary dump and it outputs assembly source code that you can massage to a form you easily can re-assemble again using a cross assembler. This tool tries to distinguish data from code (but sometimes it fails) and makes references to iNNNN and xNNNN so you more easily can relocate, add stuff etc. I think it may be the closest you will get to a commented, disassembled listing unless you find someone who has already done that.
By the way, which PET Kernal version are you working with? I think there are a couple, so you should determine that first.
-Matt
You probably know this, but many kernal functions go through a vector in RAM which can easily be redirected, so for those functions it's not necessary to change the kernal itself in order to jump out and back in; there are memory maps out there which may help you.
There is a Perl tool called recomment which I highly recommend. You take a binary dump and it outputs assembly source code that you can massage to a form you easily can re-assemble again using ... <snip>
I've found a disassembler that can take a memory map and raw bin and do that same. Haven't played with that yet.
I know I have a BASIC 4.0 4032 - but not sure about the kernel. If its a 40 column kernel from a BASIC 4.0 machine it should still work though, right?
At some point I'll need all the newest kernels but I can only work with what I have. :)
-Matt
No. I didn't know that. Thanks for the tip. :)
-Matt
-Matt
Just for clarification, in the later PETs there is the Kernal ROM and there is an EDITOR rom. The EDITOR rom is responsible for supporting the screen and keyboard, so technically you have a "40-column EDITOR ROM" and not a "40-column KERNAL". The BASIC and KERNAL roms stay the same and the EDITOR rom is selected according to 50/60 Hz, 40/80 columns, and Business/Graphic keyboard options.
Steve
