Hugo Holden
I'm thinking of buying a PET.
I have seen one where the front of the case says 3008, but the rear sticker says 2001-8 BS.
Three questions:
1) Why would it be that those model numbers are different or is that normal ?
2) Also I cannot see a DIN connector on the rear panel for a 1541 disk drive, is that because this model is too old to support that drive or is an adapter pcb required ?
3) If it cannot interface with the 1541 disk drive, what would be the first PET model that did and had the DIN connector ?
Thank you for any advice on PETs.
Three questions:
