Computek PCM210 - what is this ISA card?
Do you have a oscilloscope and/or a logic analyzer?
I would attach the scope to RCA jack and a LA to those 7 or 8 IO pins on that SUB-D connector.
Plug into a slot and look what happens.
It is not likely to do much. The RCA jack is likely driving a buzzer when activated, with a square wave. The driving circuit is typical of that type of signal. It is clearly designed to interact with something. The first thing to do is look at the code and see how it sets up the I/O pins. Things like how many pins are set to input and how many to output.
Dwight
If the printing on the card says "PCM" maybe the card takes input from the DB port, does some kind of PCM encoding on it, then sends it out again on the RCA jack. Perhaps some kind of communications device? PCM might also stand for Process Control Module. But why use a PC's ISA bus to power some industrial control with no software interaction?
I attached an oscilloscope and
RCA has a constant output of -5V, it does not change in time
DB9 pins have +5V or 0 and they do not change in time too
I suppose some of them are inputs and maybe the CPU will react to changes in those
Next I will desolder the ROM and read its content
Dump of ROM content:
View attachment computek_pcm210.zip
And the disassembly, it actually looks like making some sense, though I have not yet tried to analyse it:
	ORG	00007H
	DIS	I		; 0007
	DIS	TCNTI		; 0008
	SEL	MB0		; 0009
	SEL	RB0		; 000A
	CLR	A		; 000B
	MOV	R2,A		; 000C
	MOV	R3,A		; 000D
	MOV	R4,A		; 000E
	MOV	R6,A		; 000F
	MOV	R7,A		; 0010
	DEC	A		; 0011
	MOV	R1,A		; 0012
	MOV	R5,A		; 0013
	CLR	F0		; 0014
	CLR	F1		; 0015
	CPL	F1		; 0016
	OUTL	P1,A		; 0017
	OUTL	P2,A		; 0018
	STRT	T		; 0019
	MOV	A,#0FAH		; 001A
	MOV	T,A		; 001C
	ANL	P2,#0BFH	; 001D
	JF0	0025H		; 001F
	ORL	P2,#080H	; 0021
	JMP	029H		; 0023
	ANL	P2,#07FH	; 0025
	ORL	P2,#040H	; 0029
	MOV	A,R7		; 002B
	ANL	A,#0FFH		; 002C
	JNZ	003BH		; 002E
	IN	A,P1		; 0030
	XRL	A,R1		; 0031
	ANL	A,#007H		; 0032
	JZ	0045H		; 0034
	MOV	R2,A		; 0036
	MOV	R7,#00CH	; 0037
	JMP	045H		; 0039
	DJNZ	R7,0045H	; 003B
	IN	A,P1		; 003D
	XRL	A,R1		; 003E
	ANL	A,R2		; 003F
	JZ	0045H		; 0040
	XRL	A,R1		; 0042
	MOV	R1,A		; 0043
	CLR	F1		; 0044
	IN	A,P1		; 0045
	XRL	A,R1		; 0046
	ANL	A,#030H		; 0047
	JZ	0062H		; 0049
	CLR	F1		; 004B
	XRL	A,R1		; 004C
	XCH	A,R1		; 004D
	RR	A		; 004E
	RR	A		; 004F
	ANL	A,#00CH		; 0050
	MOV	R0,A		; 0052
	MOV	A,R1		; 0053
	SWAP	A		; 0054
	ANL	A,#003H		; 0055
	ORL	A,R0		; 0057
	ORL	A,#0F0H		; 0058
	MOVP	A,@A		; 005A
	JB1	0062H		; 005B
	INC	R3		; 005D
	JB0	0062H		; 005E
	DEC	R3		; 0060
	DEC	R3		; 0061
	IN	A,P1		; 0062
	XRL	A,R1		; 0063
	ANL	A,#0C0H		; 0064
	JZ	007FH		; 0066
	CLR	F1		; 0068
	XRL	A,R1		; 0069
	XCH	A,R1		; 006A
	SWAP	A		; 006B
	ANL	A,#00CH		; 006C
	MOV	R0,A		; 006E
	MOV	A,R1		; 006F
	RL	A		; 0070
	RL	A		; 0071
	ANL	A,#003H		; 0072
	ORL	A,R0		; 0074
	ORL	A,#0F0H		; 0075
	MOVP	A,@A		; 0077
	JB3	007FH		; 0078
	INC	R4		; 007A
	JB2	007FH		; 007B
	DEC	R4		; 007D
	DEC	R4		; 007E
	MOV	A,R6		; 007F
	ANL	A,#00FH		; 0080
	JZ	0090H		; 0082
	DEC	R6		; 0084
	CLR	C		; 0085
	CPL	C		; 0086
	MOV	A,R5		; 0087
	RRC	A		; 0088
	MOV	R5,A		; 0089
	CLR	F0		; 008A
	JC	00BBH		; 008B
	CPL	F0		; 008D
	JMP	0BBH		; 008E
	MOV	A,R6		; 0090
	ORL	A,#00CH		; 0091
	MOV	R6,A		; 0093
	CLR	F0		; 0094
	ANL	A,#0F0H		; 0095
	JNZ	00A7H		; 0097
	JF1	00BBH		; 0099
	CPL	F1		; 009B
	MOV	A,R6		; 009C
	ORL	A,#050H		; 009D
	MOV	R6,A		; 009F
	MOV	A,R1		; 00A0
	ANL	A,#007H		; 00A1
	ORL	A,#080H		; 00A3
	JMP	0B9H		; 00A5
	MOV	R5,#0FFH	; 00A7
	MOV	A,R6		; 00A9
	ADD	A,#0F0H		; 00AA
	MOV	R6,A		; 00AC
	ANL	A,#0F0H		; 00AD
	JZ	00BBH		; 00AF
	JB4	00B7H		; 00B1
	CLR	A		; 00B3
	XCH	A,R3		; 00B4
	JMP	0B9H		; 00B5
	CLR	A		; 00B7
	XCH	A,R4		; 00B8
	CPL	F0		; 00B9
	MOV	R5,A		; 00BA
	JTF	001AH		; 00BB
	JMP	0BBH		; 00BD
	ORG	000F0H
	data	0A05000A000A0A05050A0A000A00050A
	END
datasheet says that DB0...DB7 and P20...P23 are used as address inputs to the external memory during a fetch, then (implicit) the DB0...DB7 pins are used as inputs for the resulting data. Strange to use the same pins as both address output and data input... but I don't see any of that happening on the board here. I can't see where the traces go under the MCU, though... maybe they're routed under it, to the extreme left and between the pins there? (they seem to route P10...P17 on the back side)
This seems correct - the NEC Dx lines are connected to ROM Dx outputs and at the same time to the 74373 8-bit latch inputs. The outputs of 74373 go to ROM address lines. Address is latched by NEC ALE signal that triggers the 74373 to latch.
I think I am going to draw a reverse engineered schematic here. This topic becomes more and more interesting!
That is typical 8039 usage.
It might help us understand what was happening if you'd trace which pins on the connector go to the uC and which pin of the uC goes through the resistor to the base lead of the transistor?
Dwight
It looks like a combination lock in the code. Different EPROM, different combination. The RCA looks like the output.
That makes sense as the company that is current there does security systems for dental records.
Dwight
Looking at the code, P1 is only used as inputs. The only output is to the transistor that drives the RCA connector. The code does a lot of rotating and XORing based on the signals from the 9 pin connector. It is not yet clear how fast it has to run but the timer is only set to run for about 1 millisecond. I've not looked at the code deep enough to determine if it uses a single pass the counter or multiple passes. That would determine if it was connected to a key pad or an electronic key. I'm suspecting an electronic key.
Dwight
POS sounds possible. Perhaps this board generated the signal to open the cash drawer after a sale was recorded. Digital combination lock only makes sense if the board was behind the lock. An RCA jack isn't exactly secure.
Let the fun continue...
I have looked through the beginning of the code and came to an interesting conclusion that P1.4 and P1.5 must be some signals that are expected to be phase synced - change at the same time.
The algorithm seems to detect which signal is lagging behind which and tunes R7 accordingly.
Looking forward to your opinions!
; disable external interrupt
	DIS	I		; 0007
; disable timer/counter interrupt
	DIS	TCNTI		; 0008
; select memory bank 0 and register bank 0
	SEL	MB0		; 0009
	SEL	RB0		; 000A
; set R2, R3, R4, R6, R7 to 0x00
	CLR	A		; 000B
	MOV	R2,A		; 000C
	MOV	R3,A		; 000D
	MOV	R4,A		; 000E
	MOV	R6,A		; 000F
	MOV	R7,A		; 0010
; set R1, R5 to 0xFF
	DEC	A		; 0011
	MOV	R1,A		; 0012
	MOV	R5,A		; 0013
; clear flags and complement F1
	CLR	F0		; 0014
	CLR	F1		; 0015
	CPL	F1		; 0016
; clear external ports
	OUTL	P1,A		; 0017
	OUTL	P2,A		; 0018
; initialize timer to 0xFA and start it
; timer runs at 7.457 kHz, this timer run will expire (overflow) in 6 cycles
; that is 0.8 ms
	STRT	T		; 0019
	MOV	A,#0FAH		; 001A
	MOV	T,A		; 001C
; 0xBF = clear P2.6
	ANL	P2,#0BFH	; 001D
; if F0 is set, enable P2.7 (will not happen on the first run)
	JF0	0025H		; 001F
	ORL	P2,#080H	; 0021
	JMP	029H		; 0023
;  otherwise disable P2.7 and enable P2.6
	ANL	P2,#07FH	; 0025
	ORL	P2,#040H	; 0029
;; this section detects if any of P1.0, P1.1, P1.2 changed their state and kept
;; it changed for around 10ms
; check if R7 is zero (will be at first run)
	MOV	A,R7		; 002B
	ANL	A,#0FFH		; 002C
	JNZ	003BH		; 002E
; if R7 is zero: if any of P1.0, P1.1, P1.2 is zero on first run or
; changed their value from the previous check
; remember which one in R2 and set R7 to 12
		IN	A,P1		; 0030
		XRL	A,R1		; 0031
		ANL	A,#007H		; 0032
		JZ	0045H		; 0034
		MOV	R2,A		; 0036
		MOV	R7,#00CH	; 0037
		JMP	045H		; 0039
; decrement R7, if went down to zero check if P1.0, P1.1 or P1.2
; still have the changed values, if yes store the new values in R1 and clear F1
	IN	A,P1		; 003D
	XRL	A,R1		; 003E
	ANL	A,R2		; 003F
	JZ	0045H		; 0040
	XRL	A,R1		; 0042
	MOV	R1,A		; 0043
	CLR	F1		; 0044
; F1=0 if such event happened
; check if P1.4 or P1.5 changed their values
	IN	A,P1		; 0045
	XRL	A,R1		; 0046
	ANL	A,#030H		; 0047
	JZ	0062H		; 0049
; if yes, set F1 to 0 immediately
	CLR	F1		; 004B
; restore A to P1 value
	XRL	A,R1		; 004C
; replace A and R1: R1=P1 value, A=previous P1 (PP1)
	XCH	A,R1		; 004D
; PP1 >> 2
	RR	A		; 004E
	RR	A		; 004F
	ANL	A,#00CH		; 0050
	MOV	R0,A		; 0052
	MOV	A,R1		; 0053
; R0.3=PP1.5 R0.2=PP1.4 (rest is 0)
; here A contains P1 value again
	SWAP	A		; 0054
; keep only P1.4 and P1.5 on bits 0,1
	ANL	A,#003H		; 0055
; now we have on one nibble previous and current value of bits:
; A3-0 = PP1.5,PP1.4,P1.5,P1.4
	ORL	A,R0		; 0057
; now it is 0xF(PP1.5,PP1.4,P1.5,P1.4)
	ORL	A,#0F0H		; 0058
	MOVP	A,@A		; 005A
; read a value from memory depending on previous and current values of P1.5,P1.4
; | PP1.5 | PP1.4 | P1.5 | P1.4 | ADR | VAL |
; |   0   |   0   |   0  |   0  | 0x0 | 0A  | 1010
; |   0   |   0   |   1  |   1  | 0x3 | 0A  |
; |   0   |   1   |   0  |   1  | 0x5 | 0A  |
; |   0   |   1   |   1  |   0  | 0x6 | 0A  |
; |   1   |   0   |   0  |   1  | 0x9 | 0A  |
; |   1   |   0   |   1  |   0  | 0xA | 0A  |
; |   1   |   1   |   0  |   0  | 0xC | 0A  |
; |   1   |   1   |   1  |   1  | 0xF | 0A  |
; 0A - both bits behave in the same way - both change or both stay the same
; it may be interpreted as P1.5 and P1.4 are in phase sync
; |   0   |   0   |   0  |   1  | 0x1 | 05  | 0101
; |   0   |   1   |   1  |   1  | 0x7 | 05  |
; |   1   |   0   |   0  |   0  | 0x8 | 05  |
; |   1   |   1   |   1  |   0  | 0xE | 05  |
; 05 - P1.5 is lagging behind P1.4
; |   0   |   1   |   0  |   0  | 0x4 | 00  |
; |   0   |   0   |   1  |   0  | 0x2 | 00  | 0000
; |   1   |   1   |   0  |   1  | 0xD | 00  |
; |   1   |   0   |   1  |   1  | 0xB | 00  |
; 00 - P1.4 is lagging behind P1.5
; for 0x00 increment R3
; for 0x05 decrement R3
	JB1	0062H		; 005B
	INC	R3		; 005D
	JB0	0062H		; 005E
	DEC	R3		; 0060
	DEC	R3		; 0061
It is secure if it is in the box that is locked. Anyway, it looks like to may send out yet another code?
Dwight
