Chuck(G)
25k Member
Do you perhaps mean the "spindle motor"?
Something is up with the stepper motor, it does not spin as freely as the working drive with the belt removed & won't spin up the drive with the belt on.
I've got several of the 1016 drives. 100 tpi (not 96) drives all (mine are double-sided). The seek time is pretty slow--about 30 msec. track-to-track, since these drives use a leadscrew positioner with something like 4 steps per cylinder. Very accurate, but Micropolis was making precision leadscrew positioner floppies when the rest of the world had moved to much sloppier positioning. Slow 8" drives operate at better than 15 msec. track-to-track. And note the head-load/settle time--75 msec.!
The spindle motor is a simple DC brushed job, so failing mechanical damage, you may be able to free things up by re-oiling the bearings with some WD-40 or better, a light oil. The shaft should free up eventually, assuming that rust hasn't invaded the innards.
Whatever, if you've got the 100 tpi drives, don't toss them--Micropolis drives were the best of their day and quite expensive. 100 tpi floppy drives are pretty rare. If you've got the 48 tpi version, save it for parts--but for the positioner leadscrew, most of the rest of the same parts were used on the 100 tpi versions.
And pay attention to the connector pinout. Close, but not exactly the Shugart standard. For example, DS4 is on pin 34, while READY is pin 6.
