CPM-ish how to copy to another user area?
gertk
Netherlands
Hello,
Fiddling with CPM-ish on the Amstrad NC200 and having massive (32MB!) diskspace in the form of a CF card I would like to tidy up the main user area by copying/moving files over to other user areas.
This works:
COPY BBCBASIC.COM 1: (enter)
If I switch user area with USER 1 the file BBCBASIC.COM is there.
Alas trying anything with a filename with less than 8 characters (+3 ext) I get: Error, cannot open source file.
So:
COPY SBASIC.COM 2: (enter)
does not work..
Anyone else tried this ?
COPY isn't a standard CP/M command, is it?
I'd use PIP with the G parameter (user area for source files).
CPM_ish COPY.COM is used as an alternative for PIP (CPM-ish uses no DRI legacy code)
Alas (CP/M) PIP does not work (yet) on CPM-ish (it seems to mess with the interrupt locking the computer up hard, need to remove the batteries and reinstall to revive the unit)
The power button on the Amstrad uses the interrupt also..
Yes, now that my PCW has multiple virtual HDs, something like NSWP (NewSWeeP) is even more useful, as I'm making far more use of User Areas than when my maximun disk size was 720k. Makes copying between User Areas much easier. Also, there's the Mass option, where files can be tagged, among the various options available.
Regarding the original problem, maybe the COPY prog is getting confused with it's parameter parsing. If it needs 8 chars, what about
COPY SBASIC??.COM
maybe even SBASIC*.COM might be OK.
Also, maybe there's a problem with the User # alone - have you tried
COPY SBASIC.COM C2:
Geoff
I am concerned about the information that PIP does not run on your machine, and appears to have problems with interrupts and requires such drastic recovery. PIP should be the most generic and standard as any CP/M program, and certainly shouldn't be able to affect interrupts or cause hardware lockups. I'm wondering if there is something else going on here, and PIP and COPY just manifest the problem differently.
Or else your copy of PIP.COM is corrupted.
Did some more testing and it seems there is some memory/buffer corruption going on.
In CPM-ish there is an option to 'flip the disks' aka drive A gets B and B gets A and with the command FLIPDISK
If I 'flip' the disks then suddenly COPY to another user area works fine.
Need to investigate this further.
Regarding PIP not working: yes would be nice to have it working
He's using CP/Mish, which is a recreation of CP/M with no original code used. Having compatibility issues with original CP/M programs isn't that surprising therefore.
I tested the COPY.COM from cpm-ish under CPM 2.2 (on the Kaypro) and noticed the same problem.
My first assumption with the 8+3 format was not correct.
Wading through the (C) sourcecode of COPY.COM I think I found the culprit and added two setuser calls
    cpm_set_user(srcuser); // added by Gert
    if (cpm_open_file(src) == 0xff)
        fatal("cannot open source file");
    src->cr = 0;
    cpm_set_user(destuser); // added by Gert
    if (cpm_make_file(dest) == 0xff)
        fatal("cannot open destination file");
Now
COPY somefile 3:
copies as it should to user area 3 for example
I don’t think I’ve ever run across a COPY program for CP/M…
I’ve only ever used PIP. It’s (PLM) sources are included with the DRI sources for CP/M.
Many CP/M distros shipped with a COPY.COM, or similarly-named command. DRI never defined a utility with that name. But, the COPY being discussed here is something else and presumably there is source code somewhere. This discussion is not about standard DRI CP/M but something called CPM-ish.
What I am trying to accomplish is copy a file from one drive and user number to another , example:
COPY E2:JUNK.TXT A0:JUNK.TXT
Copy junk.txt from E2 to A0
Thanks
I use PPIP.com (included)
PPIP, Version 1.7
USAGE: PPIP [DU:]<SOURCE.TYP>[ [DU:][<DEST.TYP>][ /options]
<or>
PPIP [[DU:]<DEST.TYP>=][DU:]<SOURCE.TYP>[ /options]
Options (default):
/V (OFF) - do CRC Verification
/C (OFF) - print the CRC value
/A (OFF) - copy only unarchived files
/E (OFF) - delete (Erase) R/W files without asking
/W (OFF) - delete (Wipe) R/W and R/O files without asking
/M (OFF) - move files - deletes source after copy
  • ppip.zip
Koolstar42,​
That worked!! Where would I find that and other programs in 'C' or ASM or already compiled??
I never heard of PPIP before.
Thanks
Ken
I'm not sure where I found it it says Copyright (C) David Jewett,III - 1986
I think it is on one of the CP/MUG or the SIG/M disks.
Glad I could help
The CPMUG disks I have only go up to 092.
Do you ave a link to get the others?
Thanks
