Excellent news that you entered the schematics into KiCAD and ran the DRCs.
That probably means that the errors are with the original schematics. I have just printed out the original schematics and will give them a check.
We already know there is at least one error in the original schematic (discussed at post #104) which was replicated in the KiCad schematic and shows up in the production boards.
Another set of eyeballs should also verify the KiCad schematics to make sure (a) they match the original schematics and (b) check for drawing errors. Here's why:
Just now I looked into the reason for the board error that Hugo identified in post #123 noting "on board 1 there is missing copper trackwork pin 4 of the 74193 (U38) and pin 4&5 of the U27, the 7420". The original schematic correctly shows this connection. I reviewed the KiCad schematic for the board and discovered why this happened - if you look closely at the pin 4/5 connection of U27, you can see the connection drawn from pin 4 U38 terminates just short of being connected to pin 4/5 of U27. This explains why KiCad did not route the connection, and why it is missing on the board.
In case anyone is looking for them, the KiCad files are here:
GitHub - nullvalue0/Cromemco-Cyclops-88-CCC-Reproduction: Kicad reproduction of the 2-board set "88 CCC", which are S-100 boards meant for use with the Cromemco Cyclops digital camera and Dazzler video board
Kicad reproduction of the 2-board set "88 CCC", which are S-100 boards meant for use with the Cromemco Cyclops digital camera and Dazzler video board - nullvalue0/Cromemco-Cyclops-88-CCC-...
