NeXT
I have two of these.
They look to be dual port serial cards that encrypted and decrypted data through logic under the metal cover.
The 3.6v batteries are long dead so it didn't matter much when you took the metal cover off and tripped a tamper switch (probably cut off the battery to some RAM or something that held the cipher key which I hope you could reprogram through software) but I can't find a single bit of information about the card or what kind of software and drivers it required. The FCC ID (JE3-TS5000) does not show up in the FCC's database.
