Data General One EL 2T Problems
pcuser451
Hi,
So recently acquired an Data General One Model 2T with the el display, worked fine-ish however recently after plugging in the power adapter, the screen wouldn't display , then then machine wouldn't turn on. I managed to trace the issue down to a faulty/ loose power socket . The issue is I cant find a service manual or anything on how to get to the motherboard, and the only thing I can get to is the bottom soldering pins. I tried to solder those, but it doesn't seem to turn on. Can anyone help?
Thanks
It has been a while since I had mine apart, but if I remember correctly I think you have to unscrew the display hinges to take the top off.1000003787.jpg
removed hex nuts and screen, still wouldnt budge, another plastic bit cracked, a broke, i think im going to stop for now. I’m going to consider my options
First, remove the plastic DG logo below the screen to reveal screws to remove screen surround. This allows access to display cable.
I'm thinking after the hinge hex nuts are removed, those hinges are still held in place by a pin. I seem to recall having to gently pry the metal hinge inward to get it them pop out.
I do know putting it all back together was a delicate act with the display connector.
Mine makes an horrible coil whine noise
The coil is actually easy to locate, it's a transformer that is strangely out of the motherboard and put below the case
It seems to be involved in the backlight power psu
Did anyone ever encounter this issue ?
If I'm not mistaken, the potential for coil whine increases with age. As such, It's not too surprising that it is happening. I'm not aware that there is much that can be done about it though.
Hi,
Thanks
Could you take a picture of the back of the adapter? I have one too, but it doesn't have an adapter.
Mod edit: Translated to English.
With the PSU plugged in you should be able to trace the power from the socket, through the PCB to the power switch and so on.
How do you know the power socket (inlet?) is the problem? Does it work if you hold it in place just so?
