Chuck(G)
Gone, but never forgotten.
Okay, Frank--I've taken some time out. Here's what I did.
I created a 3.5" HD boot diskette with DOS 6.22 and HIMEM.SYS, RAMDRIVE.SYS and a subdirectory called "TEST". In the TEST subdirectory, I placed IMD.COM (1.17), along with IMD.HLP and the two Model 4 image files. My CONFiG.SYS looks like this:
FILES 30
BUFFERS 8
DEVICE=HIMEM.SYS
DEVICE=RAMDRIVE.SYS 2048 /E
...and an empty AUTOEXEC.BAT file, so I'm not prompted for the date and time.
I boot from that disk, COPY from TEST to whatever letter RAMDRIVE assigns, then change to that letter and run IMD. If I had 5.25" drive on a system, I used it as the target; otherwise I used a 3.5" 720K floppy as target. In all cases, single-step was off, except when a 1.2M drive was used (in that case, I also set 250K->300K). In every case, I was able to write either image to a floppy. Here are the systems I tested:
DFI 386/40 motherboard
ASUS P5A AMD K6 450
Supermicro dual P3 750MHz P6DGE
Amptron 8600 (Cyrix PR300+ Socket 7)
ABit IS7-E P4 Socket 478, 3.0 GHz
ASUS A7N266-VM (AMD Barton 2.1GHz)
Intel AN430HX P1-233MHz
All worked; about the only thing in common was that they all used VGA displays and PS/2-interface keyboards.
I've got lots more systems--all I have to do is hook them up. Note that I used a RAMdrive, so the hard disk controller wouldn't matter.
FILES 30
BUFFERS 8
DEVICE=HIMEM.SYS
ASUS P5A AMD K6 450
