thunter0512
I am trying to remove the fan & heat sink assembly from the H724 power supply in my new PDP-8/e.
The entire assembly becomes loose when I remove the 8 screws holding the two fan grills.
It appears that it should be possible to swing the assembly out towards the right but there is a 10 pin Molex? connector at the top.
The 10 pin Molex? connector won't come off despite pressing the two locking "hooks" on either side of the connector while pulling the connector upwards.
What is the best way to loosen the connector? Contact spray?
Also on the right hand side of the assembly there are 4 diodes (rectifiers) in DO-4 and/or DO-4 package with rather thick cables soldered on which disappear somewhere under the transformer.
The cables soldered to the 4 diodes (rectifiers) are thick and stiff and I am not sure if I can rotate the entire fan/heat-sink assembly with these cables attached.
What is the correct way to remove these power supply fans?
Doug you wrote earlier this year that you have replaced fans on your and Vince's H724.
Thanks for any advice.
Tom Hunter
Tom Hunter
