DEC RRD40 CD Drive broke?
iridis
Hi everyone, I need some help with this old CD Drive from VS3100. The drive is a CM201 from Laser Magnetic Storage International, connects to a SCSI controller via a single ribbon cable (images below). The drive does not seems to startup (it has a LED in front but never lit) although it can be detected as a SCSI device.
I am trying to find the culprit. There is also a LED on the controller, and it blinks, so it might work, but there is one chip that does not heat up. The drive has some DIP switches that I could not find anything online about. Any ideas?
Wow. a SCSI to LMSI bridge board. I never knew that existed.
I am assuming you are trying to load a driver for the drive/bridge board, right? I don't think that just appears as a CD drive as-is.
The LED on the drive is only lit when a CD is inserted. If it does not, the drive is not working correctly.
These CM201 drives go bad easily, I assume you have no other way to test it? (LMSI card or soundcard with LMSI interface)
For now it does not have a disk, but the drive does not show any movements, even when attempt to boot from it. I dont have any other LMSI devices.
I have part of the caddy, but missing the transparent sleeve, so I did not try to insert a disk into it.
Why would it when there's no disc inside? The way that drive works is very special. It uses a custom caddy that stays partly in the drive when a CD is inserted. That caddy also presses the "disc loaded" switch. With nothing loaded, the drive stays dead. This is normal.
ps: You have the caddy required for it, right? Otherwise, you can not do anything with it.
Btw, do you know the correct DIP switches?
If you can't get it to work perhaps you can find a native SCSI CD-ROM drive and use that instead. I'm assuming the VS3100 can work with one, although some CD-ROM drives can be configured for 512 byte sector access instead of 2048 byte, so that could play a factor.
Depending on where you are in the world I'm willing to bet I know someone who would trade you a really nice, tested and working SCSI CD drive for that.
I would trade that CM201 for a working SCSI CD-ROM, too. If you are in Europe and are interested, let me know.
But really the important question for now is if you have the caddy for the drive.
Here is some update: so I manually inserted the caddy "shoe" then a disc (very carefully) it actually works now. Then I connect it to a SUN and it even boot! Thanks for the help Timo!
Nice to hear it's still working. I have a CM-201 and four caddys on the way to me, too. :)
