Dear fellow friends of old tech. Another beauty is undergoing inspection. I have low hopes of fixing it and that is ok, but maybe some insight comes from sharing.
The machine lights the error and negative sign when turned on but shows no numbers. It is unresponsive to all keypresses except for (sometimes only) the CD (clear display) key. If it responds it shows a left aligned 0 and stays otherwise unresponsive to any further keypresses. Neither the error light nor minus sign can be cleared. Also no number can be entered.
I have carefully cleaned, reseated all boards, checked for visual anomalies, checked & measured keyboard for stuck or broken keys or reed switches and enjoyed the beauty of the machine. I also looked at it with infrared camera. Boards 1-4 are thermally more active. Boards 5-7 not so much. Resistors in power section are the hottest as usual but nothing to crazy. None of my activities have improved but also not deteriorated the lack of function.
I scoped the voltages from the power section and get the following voltages: 200v (yellow), 190v (orange), 100v (green), 7.5v (brown) and -5.8v (purple). scope lines available in the pictures for those of you who know what to look for. no clue if the voltages are good as no documentation available to me. the mitsubishi ic's seem to work on 5v.
I want to share some photos and invite your ideas on what to check or do with it to improve function. Thank you.
