Dms12444
[wiki]Category:How_To[/wiki]
While the principles involved in desoldering an [wiki="Integrated Circuit"]IC[/wiki] are the same as those for any other part, the delicate nature of the component and the large number of pins can present a challenge.
If the chip to be removed is to be used again, great care is required to ensure all joints are completely free of solder. Just one partially soldered pin is enough to hold a stubborn IC in place and locating which pin is still connected can be tricky. If a pin is not completely clear of solder, it is often easier to flow new solder into the joint and start again. Take care not to apply excessive heat which may damage the IC or fine traces on the circuit board. When done correctly, very little force will be required to remove the IC from the board; ideally, turning the board over and giving it a good tap should make the IC fall out. If you find yourself prying the chip out, check again for stuck pins. When possible, it pays to practice on junk boards and ICs before tackling important or rare ICs.
If the chip to be replaced is defective, it is often easier to cut the body of the chip away from the pins before starting, then desolder the individual pins. This approach can also be gentler on the circuit board from which the chip is being removed. As each pin is removed individually, it?s easier to detect when the pin is free so excessive heat and pressure can be avoided. With all pins removed, the holes can then be cleared of solder using a desoldering pump or solder wick. Small traces of solder are not always worth removing and can, after heating, be poked through with a wooden toothpick. It is sometimes easier and/or safer to leave the old pins in place and simply solder the new chip to the old pins sticking out from the board.
[h="2"] See Also [/h]
- [wiki]Soldering ICs[/wiki]
