DMM and CRO Voltage Measurements don't agree
RickNel
Canberra, Australia
I'm checking the power rail voltages on an early Macintosh (512k).
With a digital multimeter, the voltages check out well within spec - 4.9vdc and 12.2vdc.
However, with an oscilloscope, the voltages look like about 3.5vd and 8vdc. There is a small amount of visible ripple within about .2vdc.
Could this point to a caps problem in the PSU (what Apple calls the analog board)?
I haven't seen a discrepancy like this before....
Rick
Use both the multimeter and oscilloscope to measure a known voltage, say, a 9 volt battery.
If the oscilloscope is the one that is grossly wrong, look to see if the 'variable' portion of the channel's volts/div is off its 'Cal' position.
On old analogue oscilloscopes, that is normally a red knob, as shown [here].
