DOS: cold boot / warm boot
haglebu
Germany, Lower-Saxony, Hildesheim
One should actually think that the key combination CTRL+ALT+DEL triggers a warm start. On all my DOS computers it's so; it always was, but ... However, I have an IBM PC 5150 motherboard where this is not the case. The key combination always triggers a cold start! Also a mini program created with DEBUG, which should trigger a warm boot, creates only a cold start. Does anyone have an idea why?
I use this one:
goto begin
e 40:72 34 12
rcs
ffff
rip
0000
g
:begin
debug<c:\reboot.bat
See what that does.
I also have a 16 byte com file (reboot.com) that does the same thing if you'd like to try that one.
I tested your batch file. But it also only triggers a cold start. It would also have surprised me, because your DEBUG instructions correspond to mine. The following code is from Scott Mueller (URP, 2nd Ed., p. 828):
DEBUG
-N WARMBOOT.COM
-A 100
MOV AX,0040
MOV DS,AX
MOV WORD PTR [0072],1234
JMP FFFF:0
-R CX
10
-W
-Q
I use WARMBOOT.COM on all my PC's and it works otherwise perfectly.
