Drawing a solid circle the hard way (in GWBASIC)
CP/M User
Back of Burke (Guday!), Australia
10 CLS:SCREEN 2:FOR A=1 TO 360
20 X=50*COS(A):Y=50*SIN(A)
30 LINE(125,115)-(150+X,140+Y)
40 NEXT A
Some Notes:
Line 10 : Clear Screen
         Set Video Mode (2 : 640x200 mono)
         Begin FOR loop
Line 20 : Calculate X
         (50 = Circumference of Circle * COS of 1 to 360)
         Calculate Y
         (50 = Circumference of Circle * SIN of 1 to 360)
Line 30 : Draw Line
         Syntax :- Line(x1,y1)-(x2,y2)
         - divided 50 / 2, since 150 is where our circle
           starts the centre is around 125 for X1, same
           with Y1 to get 115.
         - Added 150 to draw complete Circle on Screen
           for X2
         - Added 140 to draw complete Circle on Screen
           for Y2.
Line 40 : Go back & add one to FOR loop
BTW, in case you're wonderning, this program has any l
ittle point, except it does some calculations in order to
produce a circle. Well I'd thought it'd be nice to get some
more arrays! :)
Cheers,
CP/M User.
"carlsson" wrote:
> Does it really generate a perfect solid circle, i.e.
> not a close/tight fan of beams?
No, not a perfect solid circle, otherwise I would have
titled this thread Drawning a perfect solid circle the
Hard Way (in GWBASIC).
Cheers,
CP/M User.
Re: Drawing a solid circle the hard way (in GWBASIC)
20 X=100*COS(A):Y=50*SIN(A)
30 LINE(200,75)-(250+X,100+Y)
40 NEXT A
Suprisingly, no-one asked how to get a rounder circle,
since the others were kinda ovalish. Oh well I guess
it's pretty straightfoward, but here's the code! :)
Cheers,
CP/M User.
"CP/M User" wrote:
Oh dear, I've got the centre of the circle all stuffed up,
this is the offending line:
which should read:
30 LINE(250,100)-(250+X,100+Y)
it looks a bit better now! :)
Cheers,
CP/M User.
