IBM Portable PC
Does anyone know who to make DRIVEPRAM work in PCDDOS?
There is a bug that prevents it's from working and a subsequent workaround.
>driveparm=^A^A^A/d:X /c /f:Y
> /|\ Refer to your DOS manual for the proper values of X and Y.
> +--- insert three control-A characters here. Edlin works best.
https://groups.google.com/forum/#!search/driveparm$20pcdos/comp.os.msdos.misc/kgICTbl3IWU/gEk7PHObo_QJ
“The proper syntax for the undocumented ^A's in the DRIVPARM
command in config.sys for IBM DOS 3.20 and higher is as follows:
(in config.sys)
DRIVPARM=^A/D:01 /F:2
The control-A must be entered with an editor such as EDLIN that will put
the character ^A in config.sys . A caret followed by an "A" will not work.”
https://groups.google.com/forum/#!search/driveparm$20pcdos/comp.sys.ibm.pc/bFwfMoN3IIc/X_X7lefG3k
DRIVPARM is undocumented only for PC-DOS. The line you need in
config.sys is this:
DRIVPARM=^A/D:1 /F:2
Notes: 1) following the = sign, that is a single ^A, Control-A. No
space, or you'll get an "unrecognized command" error.
2) above line assumes B: drive is the 3 1/2"; change /D:1 to /D:0
for A: drive
https://groups.google.com/forum/#!search/driveparm$20pcdos/comp.os.msdos.misc/GAM0QlhvCw0/VvYkIbJrIs4J
(in config.sys)
config.sys is this:
for A: drive
