drivers for an HP ether twist 16
Ben3137
Was wondering if anyone knew where I could find a drivers for an HP ether twist 16
Also, if there’s any good games or bbses and utilities I could use with my Dos and Windows 3.1 computer
Thanks
:rolleyes: 2 seconds on Google gives this ... https://theretroweb.com/expansioncards/s/hp-27245a
The second question is impossible to answer - what I may think of as a "good" game may not align with your opinion, and as you've given no indication of what the specifications of your "Dos and WIndows" machine is, I'm not going to waste time suggesting things that potentially won't run. Apart from the original 10Rogue by Epyx. It's tiny, it's ancient, it's great fun and it'll run on anything.
OP's card is part number 27247-6002, which is the 27247A.
Putting your system specs will help. Since you have Windows 3.1, I will assume it's 286-486 and probably VGA.
Most of the Apogee games are good, and all are shareware or freeware.
Thank you for the link I was having trouble finding one.
