| VCF Latam | Apr 24 - 26, 2026, | Bahía Blanca, Argentina |
| VCF Pac. NW | May 02 - 03, 2026, | Tukwila, WA |
| VCF Southwest | May 29 - 31, 2026, | Westin Dallas Fort Worth Airport |
| VCF SoCal | See you in 2027, | Southern CA |
| VCF East | Apr TBD, 2027, | InfoAge, Wall, NJ |
00100 ;*************************************************
00110 ;
00120 ; 60 HZ. RTCSR (DBL)
00130 ;
00140 ;*************************************************
00150 ORG 3000H
00160 FLAG0 EQU 0FE80H ;ZIBL TIE TO FLIP/FLOP
00170 PULSE DEFB 0 ;60HZ HEARTBEATS
00180 ;HOLDING CELLS FOR CLOCK1 (KEEP THE ORDER!)
00190 ONOFF1 DEFB 1 ;SET TO OFF
00200 TNTHS1 DEFB 0 ;CLOCK VALUES
00210 SECS1 DEFB 0 ; "
00220 MINS1 DEFB 0 ; "
00230 ;CELLS FOR ASCON1 (KEEP ORDER!)
00240 TENS1 DEFB 0 ;TENS DIGIT
00250 ONES1 DEFB 0 ;ONES DIGIT
00260 ;HOLDING CELLS FOR CLOCK2 (KEEP THE ORDER)!
00270 ONOFF2 DEFB 1 ;SET TO OFF
00280 TNTHS2 DEFB 0
00290 SECS2 DEFB 0
00300 MINS2 DEFB 0
00310 ;CELLS FOR ASCON2 (KEEP ORDER!)
00320 TENS2 DEFB 0
00330 ONES2 DEFB 0
00340 ;ASCON1-S/R TO CONVERT N(<100!) TO TWO
00350 ;ASCII DIGITS RETURNED IN TENS1 & ONES1
00360 ;NUMBER IS IN A (BASHED). ONES1 & TENS1
00370 ;ARE SET TO ZERO ON THE CALL. 'A' MUST
00380 ;B@LESS THAN 100!!!
00390 ASCON1 PUSH AF ;SAVE NUMBER
00400 XOR A ;ZERO A
00410 LD HL,ONES1 ;POINT TO ONES1
00420 LD (HL),A ;ZERO IT
00430 DEC HL ;POINT TO TENS1
00440 LD (HL),A ;ZERO IT
00450 ;NOTE HL IS LEFT POINTING TO TENS1
00460 POP AF ;GET NUMBER
00470 SBT1 SUB 0AH ;LESS THAN 10?
00480 JP P,AGN1 ;IF NO DO IT AGAIN
00490 ADD A,3AH ;CONVERT ONES1
00500 PUSH AF ;SAVE ONES1
00510 LD A,(HL) ;GET TENS1
00520 ADD A,30H ;CONVERT IT
00530 LD (HL),A ;PUT TO TENS1
00540 POP AF ;GET ONES1
00550 INC HL ;POINT TO IT
00560 LD (HL),A ;PUT IT THERE
00570 RET ;ALL DONE
00580 AGN1 INC (HL) ;RECORD THE SUBTRACT
00590 JR SBT1 ;GO BACK
00600 ;
00610 ;ASCON2 IS THE SAME AS ASCON1 (DIFFERENT CELLS)
00620 ASCON2 PUSH AF
00630 XOR A
00640 LD HL,ONES2
00650 LD (HL),A
00660 DEC HL
00670 LD (HL),A
00680 POP AF
00690 SBT2 SUB 0AH
00700 JP P,AGN2
00710 ADD A,3AH
00720 PUSH AF
00730 LD A,(HL)
00740 ADD A,30H
00750 LD (HL),A
00760 POP AF
00770 INC HL
00780 LD (HL),A
00790 RET
00800 AGN2 INC (HL)
00810 JR SBT2
00820 ;FINISHED WITH ASCON2
00830 ;
00840 ;THIS IS THE RTCISR (NOTE ADR FOR INT VECTOR)
00850 START PUSH AF ;SAVE ALL REGS EXCEPT
00860 PUSH BC ;THE PRIMES (ADD LATER?)
00870 PUSH DE
00880 PUSH HL
00890 PUSH IX
00900 PUSH IY
00910 ;MULTIPROGRAMMING ROUTINES TO BE INSERTED HERE!
00920 XOR A ;ZERO A
00930 LD (FLAG0),A ;TURN OFF THE F/F
00940 LD HL,PULSE ;POINT TO HEARTBEATS
00950 INC (HL) ;RECORD THE TICK
00960 LD A,6 ;TENTH UP?
00970 CP (HL)
00980 JR NZ,DONE ;NO CARRY-SKIP CLOCKS
00990 ;NOTE-'DONE' WILL BECOME THE REST OF THE SWITCHING
01000 ;ROUTINE EVENTUALLY.
01010 LD (HL),0 ;ZERO PULSES
01020 LD HL,ONOFF1 ;CLOCK1 ENABLE
01030 XOR A ;ZER0 A
01040 CP (HL) ;IS IT ENABLED?
01050 JR NZ,CLCK2 ;IT'S NOT
01060 CLCK1 LD HL,TNTHS1 ;POINT TO TENTHS
01070 INC (HL) ;RECORD IT
01080 LD A,0AH ;TIME TO CARRY?
01090 CP (HL)
01100 JR NZ,CLCK2 ;NO CARRY-NO DISPLAY
01110 LD (HL),0 ;ZERO TENTHS
01120 INC HL ;POINT TO SECS1
01130 INC (HL) ;RECORD THE TICK
01140 LD A,3CH ;TIME TO UPDATE
01150 CP (HL)
01160 JR NZ,DIS1 ;NO-CARRY UPDATE THE DISPLAY
01170 LD (HL),0 ;ZERO SECS1
01180 INC HL ;POINT TO MINUTES
01190 INC (HL) ;RECORD THE TICK
01200 ;DONE WITH THE CLOCK1 SERVICE NOW UPDATE
01210 ;THE DISPLAY
01220 DIS1 LD A,(MINS1) ;GET MINUTES
01230 CALL ASCON1 ;CONVERT IT
01240 LD HL,(TENS1) ;GET THE DIGITS
01250 LD (0FB59H),HL ;PUT IT ON THE SCREEN
01260 LD A,(SECS1) ;GET SECONDS
01270 CALL ASCON1 ;CONVERT THEM
01280 LD HL,(TENS1) ;GET DIGITS
01290 LD (0FB5BH),HL ;PUT IT ON THE SCREEN
01300 ;FINISHED WITH CLOCK1
01310 ;
01320 ;COMMENTS FOR CLCK2 ARE THE SAME AS FOR CLCK1
01330 CLCK2 LD HL,ONOFF2
01340 XOR A
01350 CP (HL)
01360 JR NZ,DONE
01370 LD HL,TNTHS2
01380 INC (HL)
01390 LD A,0AH
01400 CP (HL)
01410 JR NZ,DONE
01420 LD (HL),0
01430 INC HL
01440 INC (HL)
01450 LD A,3CH
01460 CP (HL)
01470 JR NZ,DIS2
01480 LD (HL),0
01490 INC HL
01500 INC (HL)
01510 ;DIS2 HAS THE SAME COMMENTS AS DIS1
01520 ;BUT THE SCEEN LOCATIONS ETC. ARE DIFFERENT
01530 DIS2 LD A,(MINS2)
01540 CALL ASCON2
01550 LD HL,(TENS2)
01560 LD (0FB79H),HL
01570 LD A,(SECS2)
01580 CALL ASCON2
01590 LD HL,(TENS2)
01600 LD (0FB7BH),HL
01610 ;FINISHED WITH CLCK2
01620 ;
01630 DONE LD A,1
01640 LD (FLAG0),A ;ENABLE F/F
01650 POP IY ;RESTORE REGISTERS
01660 POP IX
01670 POP HL
01680 POP DE
01690 POP BC
01700 POP AF
01710 EI
01720 RET
01730 ;ALL DONE (NOTE 'RET' <> 'RETI' ALSO NO 'IM2'
01740 ;
01750 ;INITIALIZATION FOR THE RTCISR
01760 ;EXECUTE INIT WITH A ZIBL 'LINK' BEFORE USING
01770 ;E G. LINK(#INIT)
01780 LD HL,START ;START OF RTCISR
01790 LD (0EH),HL ;INT7 VECTOR
01800 EI ;TURN ON THE INT
01810 LD A,1
01820 LD (FLAG0),A ;TURNON THE F/F
01830 RET ;BACK TO BASIC!
01840 ;
01850 ;**************************************************
01860 END START
01870 ;FINAL WORKING COPY 10/8/81 *****
I wonder if we could persuade the seller to dump the roms - this seems to be a unique opportunity!Yes, one surfaced on the bay just recently - the first one I have ever seen! I did think long and hard and did not bid. It was not sold but has not been relisted.
I really did want one because I had used it for a time...but sanity prevailed. I have two other retro Z-80 projects to get to (an Altos and a Master controller). BTW: Both have 2708s that I have to read to see if they are viable...and I plan on using your Arduino 2708 reader project...I don't need the 12V battery part as I plan on just using a PS with 5v and 12v...so thank you for that as it will be very useful.
You can try but I just looked at his other auctions and none are for similar items. Maybe whoever ended up with it (if it is gone) might be the better possibility for an EPROM dump.I wonder if we could persuade the seller to dump the roms - this seems to be a unique opportunity!
You know, I raised my eyebrows when I first read that in your project text but when I looked at some datasheets, they were saying similar...datasheets or somewhere else, but your warning was not the only place I read that, so I took it to heart and will make note of that. I will let you know how it goes.Re 2708s, remember the power rail sequencing is key - doesnt matter how slowly you apply the power rails as long as its in the right order, power up and down
I've an SC/MP book by Robert Dehaviland (?) which is largely based on NIBL, but he mentions a Z80 version several times - as a huge NIBL fan this intrigued me. I'd love to do a ZIBL machine!How did you come to be interested in it?
Its ZIBL itself I'm looking for... the Dynabyte board is very nice but way beyond my budget!
Glad to here from you and, alas, a tragic theftI designed the Basic Controller when I was President of Dynabyte. I appreciate everyone's interest. I no longer have any Dynabyte hardware. It didn't survive the divorce and moves and births and deaths. My last two Basic Controllers and several 5000 series Dynabyte S100 computers were stolen when I moved from Woodside to my ranch around 2002. They were all mint...
Mike Watts
I think this was designed by Hank Skawinski. Those are his initials in the upper right corner - HMS.I found the attached schematic in a pile of papers and thought someone, somewhere, might find it interesting. Has a 1980 date.
I do remember the computer; Z80 based and had an onboard eprom burner and some other nice feature...
We did. We sold all kinds of add-ons. I'm pretty sure we even offered a monitor.Really good info and thank you. I wish I had kept all the documentation.
BTW I looked at the ebay link again and that one sold for $2400. Do you remember if you sold the keyboard and PS with Basic Controller?
I feel nothing proprietary about it. Go for it!Is there any possibility for someone in the USA to contact the buyer and beg for the roms to be dumped? I dont know if you can do that on ebay.
After reading so many references to it, I would dearly love to see ZIBL.
@mike, in the interests of history and nostalgia, would you be ok with that or do you still consider it proprietary?
Cheers - Phil
