dfwJim
I had an Apple ][+ then Apple //e from 1979 through the mid-90's, and now I have recently got my hands on an Apple //e with a 5.25" Unidisk and managed to audio bootstrap it with ADTPro.
I managed to find a single 5.25" diskette after rummaging through my house twice, and I was able to transfer a couple of images to it. (Hole-punched it to write to side B.)
I went to a local store with vintage stuff to obtain some more floppies, and I bypassed the apparently-new 10-packs of trustworthy brands and "cleverly" bought the cheap bulk floppies figuring I could stand a few bad ones. Bad move. Some won't format. Others fail when receiving the disk image. None of them have booted so far except my original disk found at home which works splendidly.
Since the store closed before I could return and get the diskettes i should have bought in the first place and is closed tomorrow, I've been Googling for info and trying out different disk diagnostics. XPS //e Diagnostics shows the disk RPMs at about 298 RPM, a little shy of 300, but I don't know how critical that is. When I verify media, some of the disks are just horrid all over with bad sectors, but many only fail a bunch of sectors in tracks 0 and 1 but pass the rest of the tracks fine. If I recall, tracks 0 and 1 are on the outer edge, yes? I'm wondering if the outer tracks are more sensitive to speed.
Then I read somewhere that Apple 5.25" drives don't do well with the high-density floppy media because they don't have a reinforced hub, and sure enough my lone reliable diskette has a reinforcing ring around the center hole, and my "bargain" floppies don't. Do the reinforced hub rings make a difference?
