Drken
I acquired an EDD+ card with cable and I am having a bit of a difficult time getting it connected. I have the manuals etc for the card, but it talks only about connecting the EDD+ with a Disk ][ drive and controller. The only thing is says in the manual (that I could find) is that if you are using a DuoDisk or UniDisk, contact the manufacturer for the proper cable.
The cable I have is, I believe, that cable the manual references but I have no directions on how to connect it. The cable has the 20-pin (2x10) block connector on one end, and male and female DB-19 pin connectors on the other end, back to back. I'm hoping someone can send me the directions for connecting this cable up to Apple 5.25 Drives and Controller card. If you have any info that you can share with me, I would be grateful!
Ken
www.Apple2Online.com
Ken
