segaloco
- Joined
- Apr 30, 2023
- Messages
- 483
So I've enjoyed chatting here and learning more about transistors on the fundamental level, and just got my first batch of tubes from the antique store to play with "the old way". In general I am fascinated with the applications for binary switching, be it relays, tubes, transistors, or whatever is next. Rather than endless piecemeal topics swirling the bowl, figured I'd make this one as its a topic I just like learning and talking about. Anyway.
So I find myself with a question of tube function. My understanding is you heat a filament, like a light bulb, but the goal is electron rather than photon emission. A plate is placed a distance away such that without other influence, even with a potential between the filament and plate, the current cannot flow through the air between. The grid, placed in between and given a potential, creates favorable conditions to then draw the electrons and flow of current in a controlled direction towards the plate. This of course is then what transistor action is analogous to, what with changing the electrical conditions of a space between two potentials.
However, is there anything like a vacuum tube but that operates in a "depletion mode"? In other words, you apply a potential to turn it off, rather than on? I picked up a random array of vacuum tubes at a shop today and am trying to draw various parallels to transistor circuit design.
