dJOS
So I've been mucking about with a Covox Clone on my Tandy 1000 EX and the results frankly sucked:
So I've been reading up a bit more on the eccentricities of the Tandy Printer port and found this thread:
http://www.vcfed.org/forum/showthread.php?33992-Tandy-1000-Parallel-Ports-Part-II
which mentions the following:
I assume this should enable the Nibble mode (basic bi-directional function) from Gen 1 IBM LPT ports but I've been looking thru the EX Technical Reference Manual but I cant see any references to a "jumper" and I cant find much else on this - anyone know exactly what is meant by this?
I know the Select signal is on Pin 16 of the Parallel Chip and it's not connected to anything - I assume one would jumper this pin to another pin on the Tandy Parallel chip but I cant find anything definitive.
Anyone know more about this?
The Select Input signal can be sent to the card edge on the 1000A, 1000HD, 1000EX, 1000SX, 1000HX, 1000TX, 1000TL, 1000SL, 1000SL/2 via jumper.
