DeltaDon
I just received this monitor as non-working. It is a B&W CRT for the Epson QX-16 computer. Besides the Q602A model #, there's a FCC # of BKM678Q602A on the label plate. It was DOA when plugged in and I opened it up and found a blown 2.5a slow blow fuse. I installed a replacement and now the power light comes on on the CRT's front panel. But no joy. No sound of the high voltage/Hort circuit working. I did see a 1/2W carbon resistor that's blacken around it's middle, but it will be a PITA to reach since the PCB is attached to the lower plastics which has high sides. If anyone has a schematic or perhaps a working example I'd like to know the correct value for that resistor. (Orange, x ,gold???) Picture to follow.
