Hugo Holden
The OP said: I verified that Vcc and Vpp are correct at the chip during the programming cycle. Vpp generally holds at 25.2V but sometimes varies anywhere between 24.9V and 26.2V, which seems to be within tolerance, based on the datasheets.I believe the old TL866 could provide a higher programming voltage than the newer T48. So it might be possible that the T48 can't reach 25v.
But that would have to be tested with a scope to be sure, not a meter, because it could be transiently collapsing for short periods of current pulses, he did not say if the voltage looked ok on scoping, it sounds like a meter's measurement.
