Error 11H on boot of FreHD on TRS-80 Gate Array
mudmin
Booting from LS Dos 6.3.1 with the FreHD drivers after entering the data and time, it just keeps repeating 11H. Does anyone have any idea what this means?
Booting a floppy? That error indicates directory read error; this is typically triggered if the directory track has the wrong data address mark (DAM). This is caused by LS-DOS trying to load the directory entry for the command interpreter.
This can be caused by a faulty write of the floppy or by a hardware issue with the floppy disk controller. Or a bad floppy image.
Booting a floppy to load the FreHD. I can try a gotek in there which would mostly eliminate the floppy issue. Hopefully.
Thank you. I will give that a shot.
