Formulator
A quite clean system, but sadly will not post. Has LED display and speaker toggle. RAM tested OK in other system, (except for one DIMM from empty socket).
I suspect issue is with the InSTEP 387 upgrade board. Since this was originally a 286 board, I want to verify which type of alternate CPU to test with.
Given complexity of upgrade board, I would suspect to test with 68-pin 286, but wanted to know if a 386 would drop in, since BIOS may support it.
