per
Ok, so I am working on putting together an external floppy disk drive cabinet, which is designed to hook directly onto the cable from the internal drive in a computer. The computer is meant to work fine on it's own without the external drives, but it's also meant to work with the external drives too.
So how do I set up the termination resistors? two 150 Ohm paths to 5V would mean 67mA sink current, a little on the high side for the 74S240-chips on the controller card driving the floppy interface. One option is of course to get termination resistor-packs of higher resistance, but then on the other side, the total cable-length isn't terribly long, only half a meter or so.. It could work just having the resistor packs on the internal drive I guess?
Any thoughts on this?
