Gary C
Next up is a 4032 fat 40.
Power up and all transformer voltages present and correct, plugged into the board and +4.97, -5.06 & +11.9 so not anything to worry about
But nothing on the screen but a raster with the brightness turned up.
Quick off & on and the normal pet garbage is show for the briefest of moments then nothing.
Scope on 6502 pin 7 shows healthy activity so it doesn't look as if its crashed.
PETTEST installed, and everything looks fine except the keyboard input is showing FC FC FC FC FC FC FC and will only change when some keys are pressed.
Scoping on UB12 PIA its noticeable that the lines PA0 to PA3 are sat at high, high, low, low and arent changing which isn't right.
Not sure why that would stop the startup process but first, change the 6520 and get PETTEST to work as it should. Interestingly this is the second 6520 I have had a port failure on this month and I am still awaiting parts to repair the SK. I am thinking the 65C21N might be a better choice going forwards so I have 4 on order from Mouser.
