frank_DK
This picture is "startup" screen with a new 2124 from a C64, placed at UF7.
This is the screen after switching power OFF and ON.
The new UF7.
Could UF8 be defect too?
Boy, this PET ain't gonna give up easily, is it...As a test, when you are at the last screen shown, on the keyboard type: poke 32777, 100 and see if the '@' turns into a 'd' on the word 'Commodore'.
You may be right that there's actually garbage being written into (now) good screen RAM.
I have changed the UF8 too, also from an old C64, and now the "startup" screen looks nearly ok
Yeah, considering how notoriously unreliable the 2114s turned out to be, I'd try another replacement if you can find one.Alex,
The difference between an ASCII "/" and an "o" in the first photo indicates a possible problem on SD06 or LSD06 signals or another bad UF7 RAM chip.
... then the "startup" screen is now OK but there still come some garbage if I write long texts.
Excellent! Congratulations, glad we could help, and I'll probably lose some weight now that this thread is closing; every time I read the title in New Posts I had to go and get a couple of cookies (mmm... Danish...) ;-)So we're up and running 100%. Bought two 2114 VRAM and a 6520th It is a joy to have the old machine up and running. Are there some here who have programs to it?
... And the number of posts that it took ;-)So to summarize, this PET required replacing 1 ROM, a couple RAM and a 6520?
Maybe we should start keeping a "bill of materials" for every salvaged PET to get a figure how much work there can be in the least, average and extreme cases. Ideally also grouped by model and motherboard revision.
I know the Commodore forum here has been very heavy with PET stuff recently, maybe it's time to create a new "How To Troubleshoot And Repair Your PET" web site that we can just point people at in the future.
I'm going to try to help with Eudimorphodon's PETs as soon as we're both free, too. That'll give another opportunity to write up procedures and debugging notes.
What is the easiest way to get programs from the 'net into a PET?
Grooooaaaannnn...ANSWER: Print them out, and slide the folded sheets of paper through the IEEE 488 slot at the back of the machine.
