Zippy Zapp
I have a beige G3 tower (newer revision) that I recently repartitioned the HD to make sure the system software was located on the first 8GB and now it is doing something peculiar. When I turn it on with either the adb keyboard or the power button it does not boot at first. It makes the chime and it sounds like the HD is spinning up but it just sits there. Sometimes the power light will not be on either. The monitor does not get a signal.
If I hit CTRL + Command + ADB Power button to reset it, it chimes again, the monitor comes to life and it boots right away and works fine.
I have tried resetting PRAM, no change. I did use the reset button on the motherboard (Cuda?) and after this it boots fine but the next power cycle it is back to not booting without a reset.
It does not have the original drive and I have not tried a different drive but it was working fine with this drive before the repartition. The only other thing I have not tried is reseating the voltage regulator module. But since it does make the chime i and boots after reset I think this is likely fine.
Has anyone come across this problem? With all the years I have owned Macs I have never seen this issue.
Thanks!
Thanks!
