Bill_Loguidice
If you're asking can you approximate the basic setup of the Xbox without being in any way compatible, then the answer is "yes, of course" (you'd have to run something like Windows or Linux on it, of course). If you're asking "can I build my own Xbox?", then the answer is "no, of course not". Besides the proprietary OS and condensed design configuration, there are subtle differences like the proprietary form of USB used for the controller ports and many, many other things that make such an endeavor impossible. Again, if your concern is your Xbox breaking, which is as likely as any other modern console, then the simple answer is is that with the right skills you can replace things like the optical and hard drives yourself, which is likely all that would ever break. Certain games may refuse to run if you modify it and you'll be banned from Xbox Live most likely depending on what gets changed, but those are different issues.
Again, when you can buy new, boxed systems for not too far over $100 and refurbs and used for less than $100, what's the point?
