The system is a 5160 (third revision BIOS, XTIDE Universal BIOS v2.0.0b3), with a half-height 5.25" floppy drive and the IBM Diskette Drive Adapter (w/Intel P8272A), running MS-DOS 6.22.
Been reading quite a lot of data off some floppies. Every once in a while, a perfectly good disk would give me a "General failure reading drive A:". No matter what I choose at this prompt - from that point on every attempt to access drive A: will give the same error - the drive light doesn't even light up, it just barfs immediately every time until I warm-boot. *Then*, the same disk will often read just fine.
That only happens with this particular error: I've gotten other critical stops with disks that are actually bad ("Sector not found", "Data error", "Invalid media", and so on so forth) but they behave as you'd expect.
Any ideas? I don't see anything that could cause a DMA or IRQ conflict. It's just an annoyance, since a restart does fix things, but I'd be happier if it stops happening...
