Getting a seco Socket 7 SBC to work
soviet9922
Montevideo, Uruguay
Found a SECO MTL M 94V-0 4309 SBC board, could like to make a sort of mini retro pc out of it.
This board looks quite cool has a Pentium MMX socket 7 CPU, and lots of I/O including audio (there's a crystal chip on the backside of the board).
Now the PSU connector is easy to figure out the voltages are written next to it, the issue is that I need to find out if any of the connectors is for PS/2 in the board there's a header marked as "UTILITY" maybe that is the correct one ?.
Also need to figure out if the pinout for the "CRT" connector maybe is a VGA output.
There's a tiny plug also that says "USB" that may be ok to plug a keyboard into it.
Maybe someone knows the pinouts for this or where to find the manual or maybe from a similar board.
The seco.com site was used by other companies until 2007 and the stuff there is much newer than this board.
Now looking at it see more markings like "CS473-REVD" "BD revD 2"
