agentb
Anyone tried hooking up a gotek to a UNIX PC (3b1)? I'm going to mess around with this at some point. I still don't fully understand the MO (motor enable) jumper on the gotek, do I want this jumpered for 3b1?
Jumper Setting | Drive Emulated | Floppy 360K Present | Machine Response |
JA & S0 | B | Yes | "Ready, ROM error" |
JA & S1 | B | Yes | Not ready on A. ROM Basic not available. Press reset (Note: Floppy A lamp lighted while emulator light out) |
S0 | B | Yes | Not ready on A. ROM Basic not available. Press reset (Note: Both LED's on Floppy A and the emulator are lighted) |
S1 | B | Yes | Not ready on A. ROM Basic not available. Press reset (Note: Both LED's on Floppy A and the emulator are lighted) |
JA & S0 | A | No | Not ready on A. Primary Boot Strap, flashing press restart to reboot." (Note: Emulator Lamp out before and after POST. LED thumb drive on for 1-3 sec used right button to load buffer before sequence of boot.0 shows buffer loaded from 0 also LED on thumb drive illuminated) |
JA & S1 | A | No | "Ready on A. Primary Boot Strap, flashing press restart to reboot." (Note: Emulator Lamp out before POST, however, Emulator Lamp on after POST for 1 sec. LED thumb drive on for 1-3 sec used right button to load before sequence of boot. D0 shows buffer loaded from 0 also LED on thumb drive illuminated) |
S0 | A | No | Not ready on A. ROM Basic not available. Press reset (Note: Emulator Lamp out before and after POST. LED thumb drive on for 1-3 sec used right button to load buffer before sequence of boot. D0 shows buffer loaded from 0 also LED on thumb drive illuminated) |
S1 | A | N0 | "Ready on A. Primary Boot Strap, flashing press restart to reboot." (Note: Emulator Lamp out before POST, however, Emulator Lamp on after POST for 1 sec. LED thumb drive on for 1-3 sec used right button to load buffer before sequence of boot. D0 shows buffer loaded from 0 also LED on thumb drive illuminated) |
Got the gotek working with FlashFloppy!
David even provides a fully loaded HD to get you started: http://www.pdp8online.com/3b1/demos.shtml
Do you know if a 3B1 disk image would work?
'LD_LIBRARY_PATH=../libdisk ./disk-analyse -v 01.imd 01.hfe'
If you use the FlashFloppy firmware, there is no difference between 720 and 1.44 Goteks; they are identical from a hardware point of view.First, I commend you for getting it to work. As I mentioned in my post, I couldn't get it to work under DOS 6.22 and ROM 1.43.
What size was your GoTek drive 720 or 1.44 Floppy?
