Gridcase 2 - Power supply voltage
Atomtan
Leicester, UK
Sorry if this is a stupid question, I could tell the 2 x RIFA's in the power supply were starting to go and so I swapped them for like for like replacements.
Before I did this, the supply voltage (using the same meter) was around 15.6v. I notice now that it sits somewhere around 14.75v. Is this voltage now too low?
NeXT
Kamloops, BC, Canada
The RIFA's are on the primary side. Replacing them should never alter the secondary output voltage, or any of the voltages at all.
The rest of the PSU however is known to have age-related cap issues. Have you fully serviced it?
daver2
10k Member
UK - Worcester
powerlot
Europe
UUmmmm...what's RIFA?
Oh... you have yet to experience the nose-hair singeing stench of a blown filter cap...
Apart from the already explained intended function as filters, RIFA branded safety caps are infamous because after >20 years the plastic casing cracks and moisture ingress makes them go boom.
Here some samples I pulled out of equipment:
The big one is primed for explosion as you can see on the split in half case, the others aren't far behind.
They're also hidden in the IEC power inlet filter cans (Schaffner branded, for example). I fell for it because I was confident I checked everything, but didn't know those filters can also explode.
If anyone has old stocks of these, they can all be thrown out.
