Gutting a Gateway 2000 Colorbook
dylanrush
I have one working Gateway 2000 Colorbook in great condition aside form a dead CMOS battery.
I have another that I got on eBay for around $40 shipped with obvious water damage. Lots of rust on the outside a bit on the inside and the main board.I bought it thinking I might be able to get one or two spare parts. The battery looks fine. I am thinking the screen, keyboard and trackball probably also work.
I am thinking of gutting it and putting a raspberry pi in there.
Pictured is the interface to the display - the bundle of green, yellow, white and grey. What are the chances that this is a signal that I could replicate? It's probably not VGA, right? (Can't be - too many wires). Would I need an oscilloscope to try to reverse engineer it? Or is there a common intermediate digital signal that laptops of this era would have used?
The cable from the screen to the board is generally not standardized, but the screen itself does have a display standard. It's probably some type of LVDS signaling. You'll have to disassemble the screen to get a part number off of it.
There are cheap Chinese adapter boards that can drive LVDS monitors and give you a variety of display connectors. VGA and HDMI are pretty standard, you just have to get the cable going to the screen wired correctly.
What's the part number of the LCD? If you're lucky, there will be a datasheet available with the pin-out. It's likely some kind of parallel signaling.
Do be aware that the Colorbook's LCD is a low quality passive matrix display, so make sure the effort of doing a pi retrofit will be worth it to you :)
