vrs42
I thought I might make this it's own thread, so it is a little easier to find the information.
I've recently built a replacement power harness for the H724 in my PDP-8/E, and I plan to describe the process, hopefully in a series of posts with enough information to allow others to succeed, without too much trouble.
I found the old post which has the part numbers for the pins and housings for the power supply end. Here it is again:
I used these, with the a Twippo SN-48B crimper which I acquired on eBay, and a selection of 14 gauge automotive wire I bought on Amazon. The wire insulation isn't the original teflon, which I think was probably overkill, and is considered problematic these days. It also isn't the original assortment of wire gauges; essentially I have up-sized everything to the 14 gauge that the red wire requires.
It should be noted that 14 gauge is at the limit for the pins and the crimper, so you'll want to be sure your crimps are turning out well. I found that the Twippo crimper made excellent crimps. Positioning the pin and wire perfectly while engaging the ratchet was the hardest part.
I did find that I had some pins lying around which were compatible with the housing and the socket, but when I tried to use them up I discovered they were too small to accommodate #14 wire.
Next up: Wire colors, placement and lengths
Vince
TE Connectivity Commercial MATE-N-LOK
Power supply side:
Shell 1-171196-0
Pins 60619-1
Cable harness side:
Shell 1-163035-0 or 1-480276-0
Pins 60620-1
Vince
