Gary C
Got my hazeltine terminal on the bench and its a bit sick.
The monitor wasn't working but that was a simple fix, its the logic board thats not running properly.
On RAM chip pulling down an address line was easy to sort, but while there is lots of activity, the databus is not right
D2 on the CPU side to the bus driver is like this for example. Its almost running though.
Probably try replacing the bus driver first after a good clean up.
