ECNeilson
I'm letting my Z-100 go to make room for other projects. In addition to the computer, I have over 200 Z-100 software titles on 5 1/4" floppies and just about every manual ever released for the Z-100 series computers. Please note: The hard drive has finally failed after 30 years and the floppy drive is no longer booting so the Z-100 needs a little attention before it's fully operational again. It has served me well though and I would like to give it a good home. The pictures below show the Z-100 and all of the manuals. I've also attached a software inventory of everything you will get. If it's a commercial title, it's probably the original master. All of the HUG disks are originals as well. Also included is a Z-100 Diagnostics software package that includes a Dysan alignment disk for the Z-100. If you can get the floppy drive booting again (or replace with a working drive), you can do your own disk alignment.
And you get a working Gemini board too!
$400 Cash and Pick-up only. I'll knock off $50 if you pick everything up by Saturday.
Here are the system specs (this was the late model Z-100 with the 8 MHz processor and maxed out 4MB RAM):
Monitor ROM: v2.9
CPU: 8088/8085 at 8MHz
OS's supported: CP/M-85, CP/M-86, CP/M Plus, MS-DOS 3.1, ZDOS
RAM: 4 MB (DOS), 768K (CP/M)
Video (Color): 64K
Disk Drive: Internal 5 1/4 Disk Drive, DSDD, 360k, 300 rpm, Not Working
Hard Drive: Winchester Internal Hard Drive and Z-217 Controller card, Not working
Serial Ports: J1, J2 - ($ECH), Port 2, 9600 N81, Hardware handshaking
Power Supply: 240 Watt with +5, +8, +12, +- 16 volt outputs - Fan replaced for quieter operation
The complete software inventory is listed in PDF format here (couldn't attach):
https://www.dropbox.com/s/qw43qf96o2f7jue/z100_specs_inventory.pdf?dl=0
All of the disks are labeled and very well organized. I also have copious notes on the system you are welcome to have a copy of as well.
Update 1/1/16: By popular request, I've updated the PDF on DropBox to show which software titles are original master diskettes. About a year ago I tested each test to make sure it was readable. Any titles not readable were removed from inventory. I've also listed just the original software master disks below.
Z-100 Software on Original Master Disks
Access Communications by Hilgraeve Inc. v2.10
Alta Systems Super Zap disk sector editor
Autodex for CPM
BIOS for the Heath-Zenith Z-150 PC
BIOS v2.32 for MS-DOS 2.0 (1983), compiles to IO.SYS
BIOS v3.00 for MS-DOS 2.0 (1985), compiles to IO.SYS
Both Sides Printer Uitlity
Catalog Master
Computer Chef recipe file
CP/M CopyDOS
CP/M HUG File Manager and Utilties
CP/M Utilities by PS
CP/M Utilties
CP/M-85 Keymap
CPM-86 Keymap
CPM-86 Utilities by PS
CXREF C Cross-Reference utilities
DSBackup+ v2.5 hard drive backup utility
Ed-A-Sketch graphics editor
EZ-PLOT II
File diffing utilities
Heath-Zenith C/80 3.0 compiler and runtime library - Disk 1 of 2
Heath-Zenith C/80 3.0 compiler and runtime library - Disk 2 of 2
Heath-Zenith CP/M 85 - July 1982 - Disk 1 of 2
Heath-Zenith CP/M 85 - July 1982 - Disk 2 of 2
Heath-Zenith CP/M 85 - June 1983 - Disk 1 of 2
Heath-Zenith CP/M 85 - June 1983 - Disk 2 of 2
Heath-Zenith CP/M 85 - June 1983 - Disks 1 and 2 in ImageDisk format
Hoyle & Holye Software Calc3
Hoyle & Holye Software Prepare (Works with Calc3)
Hoyle & Holye Software Query!3B (Works with Calc3)
HUG Utilities
Interrogator Drive Diagnostics Program with Dysan alignment disk
Keymap for H8/H19 or H/Z89/90/100
Laptop Utilities for PC Compatibles
MAC assembler from DRI - Heath-Zenith distribution disk
Microsoft Basic for Z-100
Microsoft MultiPlan v1.2 (5 Disks)
Microsoft Windows Beta Build for Z-100 Disk 1 of 5
Microsoft Windows Beta Build for Z-100 Disk 2 of 5
Microsoft Windows Beta Build for Z-100 Disk 3 of 5
Microsoft Windows Beta Build for Z-100 Disk 4 of 5
Microsoft Windows Beta Build for Z-100 Disk 5 of 5
Microsoft Windows v1.0 for Z-100 Disk 1 of 5
Microsoft Windows v1.0 for Z-100 Disk 2 of 5
Microsoft Windows v1.0 for Z-100 Disk 3 of 5
Microsoft Windows v1.0 for Z-100 Disk 4 of 5
Microsoft Windows v1.0 for Z-100 Disk 5 of 5
Microsoft Z-Basic
MS-DOS v2.10 for Z-100 in ImageDisk format bootable with HD support
MS-DOS v2.13 for Z-100 - preconfigured wit no subdirectories
MSDOS CP/Emulator II and ZEMulator
MSDOS DPATH
MSDOS Grade r1
MSDOS HADES file recovery applications
MSDOS HELP Programs
MSDOS HUG Background Print Spooler
MSDOS Screen Saver Plus
MSDOS Small-C Compiler Disk 1 of 2
MSDOS Small-C Compiler Disk 2 of 2
MSDOS Spell5 and Spell5F
MSDOS ZPC Support Disk
MSDOS ZPC Upgrade Disk
MSDOS ZPC v2
Optimizing C86 Compiler - Disk 1 of 3
Optimizing C86 Compiler - Disk 2 of 3
Optimizing C86 Compiler - Disk 3 of 3
Original Adventure game ported from UNIX
Pack/Crypt file compression/encryption
PeachText 5000 for Disk 1 of 6
PeachText 5000 for Disk 2 of 6
PeachText 5000 for Disk 3 of 6
PeachText 5000 for Disk 4 of 6
PeachText 5000 for Disk 5 of 6
PeachText 5000 for Disk 6 of 6
Pie full screen editor
PS'S PC and H/Z-100 MS-DOS Utilities
PS's PC Utilities (PC Compatible Series)
Query III applications program
Screendump v3.52 Disk 1 of 2
Screendump v3.52 Disk 2 of 2
SmartKey v3.2 keyboard redefinition program
Snake action game
Spelling proofreader
SuperCalc Disk 1 of 2
SuperCalc Disk 2 of 2
Text formatter
Text formatter
Touch Typist
WatchWord word processor v2.0 for ZDOS
Word Wiggle word game
WordStar 2000 Plus (20 disks)
Wordstar v3.31 for Z-100 Disk 1 of 5
Wordstar v3.31 for Z-100 Disk 2 of 5
Wordstar v3.31 for Z-100 Disk 3 of 5
Wordstar v3.31 for Z-100 Disk 4 of 5
Wordstar v3.31 for Z-100 Disk 5 of 5
Wordstar v4.0 for Z-100 Disk 1 of 5
Wordstar v4.0 for Z-100 Disk 2 of 5
Wordstar v4.0 for Z-100 Disk 3 of 5
Wordstar v4.0 for Z-100 Disk 4 of 5
Wordstar v4.0 for Z-100 Disk 5 of 5
Wordstar v5.0 for Z-100 Disk 1 of 5
Wordstar v5.0 for Z-100 Disk 2 of 5
Wordstar v5.0 for Z-100 Disk 3 of 5
Wordstar v5.0 for Z-100 Disk 4 of 5
Wordstar v5.0 for Z-100 Disk 5 of 5
Wordstar v5.5 for Z-100 Disk 1 of 5
Wordstar v5.5 for Z-100 Disk 2 of 5
Wordstar v5.5 for Z-100 Disk 3 of 5
Wordstar v5.5 for Z-100 Disk 4 of 5
Wordstar v5.5 for Z-100 Disk 5 of 5
Z-Tour 1000 for ZDOS
ZDOS Games Context Package Disk 1 of 2
ZDOS Games Context Package Disk 2 of 2
ZDOS HUG Editor
ZDOS Spreadsheet Contest Package Disk 1 of 3
ZDOS Spreadsheet Contest Package Disk 2 of 3
ZDOS Spreadsheet Contest Package Disk 3 of 3
ZDOS ZBASIC Games Disk
ZDOS/MSDOS 8080 to 8088 Translator
ZDOS/MSDOS Adventure
ZDOS/MSDOS DEBUG Support Utilities
ZDOS/MSDOS EZPLOT
ZDOS/MSDOS Helpscreen
ZDOS/MSDOS HEPCAT (HUG Engineer's and Programmer's CAlculation Tool)
ZDOS/MSDOS Poker Party
ZDOS/MSDOS Z-100 PC Emulator
Zencalc electronic spreadsheet
Zenith MS-DOS v2.0 for Z-100 Disk 1 of 3
Zenith MS-DOS v2.0 for Z-100 Disk 2 of 3
Zenith MS-DOS v2.0 for Z-100 Disk 3 of 3
Zenith MS-DOS v3.10 for Z-100 Disk 1 of 2
Zenith MS-DOS v3.10 for Z-100 Disk 2 of 2
Monitor ROM: v2.9
Video (Color): 64K
Autodex for CPM
Catalog Master
CP/M CopyDOS
CP/M Utilties
CP/M-85 Keymap
CPM-86 Keymap
EZ-PLOT II
HUG Utilities
Microsoft Z-Basic
MSDOS DPATH
MSDOS Grade r1
MSDOS HELP Programs
MSDOS ZPC v2
Snake action game
Text formatter
Text formatter
Touch Typist
ZDOS HUG Editor
ZDOS/MSDOS EZPLOT
