I have a IBM Convertible 5140 that behaves this way:
After power switch is pressed, it produces a continuous beep and nothing more. Watching other 5140 videos on youtube, it seems that this beep should be very short. Disassembling the BIOS I saw that between the beep on and the beep off instructions there are some test operations.
I modified the BIOS to produce a changing beep, and it is produced without problems:
What do you think I should do next?
