modem7
10k Member
The brown stuff is lacquer (what the wire in the transformer/filter gets coated with). It's not unusual to see lacquer there. It's quite a bit, but I wouldn't consider that to be an definite indicator of overheating.
The 5155 PSU should be able to handle the 10mhz Turbo 8088 motherboard.
The symptoms you describe could be caused by a ruptured line suppression capacitor. See the 'Line Suppression Capacitor' section of http://members.dodo.com.au/~slappanel555/failure.htm
In your photo, the two blue things are line suppression capacitors. They look okay in the photo, but take a close look at them. In my 5155 PSU, there's also one wired directly to the contacts on the power switch.
Of course, there are other components that can arc/smoke.
One way of detecting the location of arcing is to operate the equipment in a dark room, being extra careful due to the greater risk of shock (e.g. difficulty seeing opened PSU).
