Very long time lurker, first time poster.
I’m volunteering at a museum and we’re starting to put together information on various artifacts. This machine (I believe it is a Lilith) caught my eye, and the more I read the more I wanted to know. I can’t DM yet so I’m hoping jdreesen at least might see this.
The pics are what we have. It is possible there might be documentation and other cables, and I’m hoping there is a mouse somewhere but have not found it yet. The keyboard was with the unit but from pictures online I'm assuming it was a later addition or replacement.
My questions to those more knowledgeable (and thank you in advance for any help/advice):
1. Case History: Does the wooden case, drive, PSU, and card cage configuration indicate a very early production run? I saw it came from Provo, Utah, and wondered if there was a "cabinet shop next door" arrangement or if the owner knew a builder. It seems odd given most computers (including the Diser Liliths) were metal.
2. CHM Comparison: Looking at the Computer History Museum's very similar looking machine, we seem to be in a similar place in history. Can I comfortably say this is from the same place/production run?
3. Monitor Orientation: The monitor is not vertical (portrait) as I've seen in earlier and later images. Does this imply it was used for a different purpose than running the standard GUI?
4. Drives: The presence of the Honeywell Bull drive sounds like an earlier machine, whereas images of the "smaller wood case" variants seem to use an alternate drive (e.g., this pic from Byte). Does this date the machine?
5. Expansion Cards:
I hope there may be an option to restore this and try to reclaim any data that might be on the disk (I am aware of the Honeywell Bull drive warnings about not powering up before repair work). That is likely a future project, but for now, I want to write up accurate display information for the museum.
Apologies for the picture quality; the lighting in the room was difficult!
5. Expansion Cards:
- Completeness: From the cards installed, does this look like a complete setup that could theoretically run?
- HP Connector: The card with an HP serial connector. Would this be for controlling HP instruments, or perhaps peripherals like a plotter?
- Custom Wire Wrap card: It has 4 IDC headers. Could this be a custom controller for industrial equipment or perhaps data acquisition?
